Data/Hora: 04 mai 2024 10:22
 Tenere Story
Mensagem Tenere Story
Em Ingles, quando tiver tempo traduzo :cool:
In 1983 Yamaha produced the first 600cc single cylinder Enduro. The XT600Z Ténéré was named after the most difficult section of the Paris-Dakar Rally. It started a new trend in Enduro bikes. With its large 28 litre fuel tank and long-travel (255/235mm) suspension, it no longer had much in common with its predecessors, the XT500/XT550. It was in total contrast to the XT500 with its small tank and modest spring travel.
This first model is commonly referred to as the 34L model in many countries.
It was the first time the MONOCROSS system, well known on motocross models, was used on an Enduro bike. This transformed the heavy (165kg) Enduro in to a perfect touring machine for motorcycle travellers. The engine produced 43HP with a flexible but extremely strong performance at low engine speeds. The 34L model Ténéré was successfully sold for 3 years from 1983 to 1985.
A few small modifications were made in 1985 and this is referred to as the 55W model in some countries but this model is essentially the same as the 34L model.
Model XTZ600
Years built 1983 - 1985
Displacement 595cc
Power 43HP
Torque 49Nm
Starter Kick
Fuel tank 28 L
Wheels f / r 21" / 18"
Suspension f / r 255 / 235mm
Dry weight 165kg
In 1986, Yamaha made several major modifications to the Ténéré. This model is commonly referred to as the 1VJ model in many countries.
In addition to the kickstarter it received an electric starter. The air filter box was moved from under the seat to under the fuel tank. This reduced the capacity of the fuel tank to 23 litres. The fuel tank also had lowered sides which improved weight distribution. However, then a fuel pump was necessary. The oil cooler was mounted in front of the cylinder head on the right hand side. With this change and the lowered tank sides, suddenly the Ténéré had engine overheating problems. Yamaha tried to overcome this problem with longer stud bolts at the cylinder head and an increased diameter (from 27mm to 28mm) in the secondary throat of the carburettor. But the latter not only increased fuel consumption but led to irregular engine running at high altitudes. Spluttering Ténérés were not a rarity in these years on alpine passes.
Model XTZ600
Years built 1986 - 1987
Displacement 595cc
Power 46HP
Torque 49Nm
Starter Electric / Kick
Fuel tank 23 L
Dry weight 179kg
Altogether the 86/87 model badly damaged the reputation of the Ténéré as a reliable travel companion. By attacking only the symptoms one does not solve the fundamental problem.
Therefore in 1988, with the third model, more major modifications were made. This model is commonly referred to as the 3AJ model in many countries.
A frame-mounted fairing with twin headlights and a small screen provided better travel comfort. The small shaky speedo and tacho were replaced by large round instruments. The rear wheel received a disc brake. The overheating problems of the 86/87 model were eliminated with the transfer of the front mudguard to directly over the wheel. Also the cooling fin surface area was increased by one third. In addition, the lubrication circuit was optimised and fifth gear was strengthened. Thus the Ténéré again became a reliable long-distance touring companion.
Model XTZ600
Years built 1988 - 1990
Displacement 595cc
Power 46HP
Torque 49Nm
Starter Electric
Fuel tank 23 L
Dry weight 185kg
In 1991 the XTZ660 appeared, the last model of the single cylinder Ténéré. This model no longer has much in common with the first Ténéré. The petrol tank shrank again to 20 litres and the suspension travel was shortened to 220mm at the front and 200mm at the rear. The whole appearance of the XTZ660 model was lower, heavier and longer than the original 1983 model.
More than the appearance, the new engine characterised this Model. The first single cylinder with five valves provided a agreeable engine characteristic The engine is not quite as flexible as that of the original Ténéré, but in the middle and upper range it clearly had more power. The oil tank was moved again into the frame - same as the XT500 - and water-cooling provided more stable engine temperature control. The somewhat longer wheelbase provides better straight line stability at high speed and the dual-piston front disc brake provided better stopping power.
Altogether the XTZ660 is a good-natured, solid Enduro which does not, however, have much in common with the concept of the first Ténéré. For trips on desert routes, which was the original idea, it should only be used with caution. In 1994 Yamaha added a broad fairing with double headlights, but this did not have much impact on sales of the XTZ660 Ténéré. Thus production was stopped in 1999.
Yamaha now had no model between the fast twin-cylinder XTZ750 and the new light single cylinder machines.
Model XTZ660
Years built 1990 - 1999
Displacement 659cc
Power 48HP
Torque 57Nm
Starter Electric
Fuel tank 20 L
Wheels f / r 21" / 17"
Suspension f / r 220 / 200mm
Dry weight 195kg
In 1989 Yamaha present the Super Ténéré. The new developed two-cylinder twin engine has five valves and downdraft carburettors. The Model set new maximum performance values in the Enduro scene. It's not as light as a single cylinder bike and so not to use for everything. But if one gets used to the weight you can use it quite well off road. The Super Ténéré is a solid motorcycle for travelling long distances with much comfort.
Model XTZ750
Years built 1989 - 1996
Displacement 749cc
Power 68HP
Torque 67Nm
Starter Electric
Fuel tank 26 L
Dry weight 226kg
Em 2008, sai a muito aguardada renovação da xtz 660 tenere
Rally raid bodywork
22-litre fuel tank
Engine type: Liquid-cooled, 4-stroke, 4-valve, single cylinder, SOHC
Displacement: 660 cc
Bore x stroke: 100.0 x 84.0 mm
Compression ratio: 10.0:1
Maximum power: Max. power 35.6 kW (48.4 PS) @ 6,100 rpm
Maximum torque: Max torque 57.5 Nm (5.87 kg-m) @ 5,500 rpm
Lubrication system: Dry sump
Carburettor: Fuel injection
Clutch type: Wet, multiple-disc coil spring
Ignition system: TCI
Starter system: Electric
Transmission system: Constant mesh, 5 speed
Final transmission: Chain
Fuel tank capacity: 22 L
Oil tank capacity: 2.9 L
Chassis: Steel tube diamond shaped
Front suspension system: Telescopic forks
Front travel: 210 mm
Rear suspension system: Swingarm (monocross)
Rear travel: 200 mm
Front brake: Double disc, Ø 298 mm
Rear brake: Single disc, Ø 245 mm
Front tyre: 90/90-21 M/C
Rear tyre: 130/80-17 M/C
Dimensions -
Length (mm): 2,246 mm
Width (mm): 865 mm
Height (mm): 1,477 mm
Seat height (mm): 895 mm
Wheel base (mm): 1,505 mm
Minimum ground clearance (mm): 245 mm
Dry weight (kg) 183 kg
Filipe Bastias
Live as if your were to die tomorrow. Learn as if you were to live forever...
28 abr 2009 09:43 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mensagem Re: Tenere Story
Excelente post :thumbsup:
deixa-me contribuir um pouco :
Yamaha XT550 Teneré Prototype 1982
A strange idea?
Of course Yamaha's European product planning picked up on this new market trend. They caused a surprise in the Yamaha Japan headquarters in 1981, when they suggested to produce a replica of the Rally machines with a 30 litres fuel tank and a big single, or even a twin, engine. This was a concept hard to understand in Japan, where the adventure dream had not picked up yet, and nobody could imagine normal motorcyclists wanting to ride around with these big fuel tanks.
But the engineers finally took up the challenge and created the first Ténéré for the model year 1983!
Source yamaha-motor.de
28 abr 2009 11:04 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
25 Anos de Tenere :
http://www.filmpjes.nl/v/tJfUW5_aXsT
28 abr 2009 11:13 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Eheh muito bom :)
Filipe Bastias
28 abr 2009 11:25 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Como modesta contribuição, penso que faltou exibir esta versão:
a Yamaha produziu-a entre 1996 e 1999, voltando às 2 ópticas frontais e aumentando a superfície de carenagem. (enfraquecendo-a, também...)
Os 25 anos!
06 ago 2009 16:40 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Muito bom mesmo e para rematar :
Imagem Imagem
06 ago 2009 16:54 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Já agora:
será a avozinha?
Vejam também aqui um outro trabalho sobre a história da Yamaha Ténéré!
http://wiki.taringa.net/posts/autos-mot ... dakar.html
Está magnífico !!!
26 ago 2009 15:12 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
As Ténérés são clássicas aqui no Brasil, e muito confiáveis.
Ao contrário das novas XTRs, que tem dado muitos problemas.
Sem falar que a nova Té nem veio ainda para o Brasil né? :stupid:
Robson Giovanni Parisoto.
Jaborá, SC - Brasil
26 ago 2009 19:41 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Que tipo de problemas têm tido com a XTRs? É que a nova XTZ 660 pouco varia de XTR em termos de mecânica (mesmo motor, mesmos problemas, suponho :confused: )
XT 350cc
XT 750Z Ténéré
27 ago 2009 01:22 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Guerra Escreveu:
Guerra!
Aqui é o seguinte, eu monitoro isso no XT600 Brasileiro, então, vai o que tem de "normal", e eu tenho milhões para atualizar ainda... :grrr:
Lista de Problemas e Soluções:
Vazamento de Óleo no Motor:
Dica: Solicitar garantia e abrir o motor
Robson - 2005 - 700 km - custo zero, trocadas juntas - Diagnóstico: parafusos internos frouxos
Scovar – 2007 – 950 km – custo zero, problemas de usinagem
Farol Derretido:
Dica: Pedir troca na garantia, trocar lampada da sinaleira... Clique aqui para ver o tópico.
Lamarca - 2006 - (Falta Km, custo e diagnóstico)
Fabio660 - 2005 - (Falta Km, custo e diagnóstico)
Paulo - 2005 - (Falta Km, custo e diagnóstico)
Mago - 2005 - 20.000 km
Edu - 2006 - 4.500 km, trocado na garantia e sem custo
Daniel Sorroce - 2005
Alex Ramos - 2007 - 27000km - Trocado na garantia
Queda das Borrachas dos Escapamentos:
Dica: Solicitar na garantia
Fhamaral - 2006 - 5.800 km
Paul - 2005 - (Falta Km, custo e diagnóstico)
Mago - 2005 - 8.000 km
Wlibano - 2006 - 23.000 km
Wagner Caarapó – 2006
Rafacampinas – 2006 – 6.000 km
Alex Ramos - 2007 - 20000km - Trocada na garantia
Ruy-MT – 2007 – 1.500 km – Colada com cola de motor
Quebra da Base do Pedal de Câmbio:
Muca22 - 2007 - 250 km
Quebra da Roldana da Corrente:
Dica: Usar as da XT600E ou DT200
Romulo-DF - 2005 - (Falta Km, custo e diagnóstico)
FUCHS - 2006 - (Falta Km, custo e diagnóstico)
fhamaral - 2006 - 7.500 km
Edu - 2006 - 2.000 km
Edu - 2006 - 3.000 km
Wlibano - 2006 -
Juca pirambuca - 2006 - 7.300 km
Kezaum - 2006 - 2.000 km
Daniel Sorroce – 2005
Rafacampinas – 2006 – 2.000 km
Alex Ramos - 2007 – 3.000 km – R$ 6,00
Riba Jr - 2007 - 6.500 km
Duzão – 2007 – 800 km
Sensor da Borboleta (onde?):
Dica: Preciso de uma dica
Raios da Roda Oxidados:
Dica:
Dinelli - 2005 - trocados na garantia... mas voltaram a oxidar...
Alex Ramos - 2007 - 15000km - Vou trocar antes que acabe a garantia
Quadro Elástico (pintura descascando):
Câmbio travado (o que houve?):
Dica:
Joca - 2006 - 12.000km, resolvido na garantia, passagem de óleo entupida no cambio Veja o tópico
Fabio Carvalho - 2006 - 1.300 km, resolvido na garantia, passagem de óleo entupida no cambio Veja o tópico
Desgaste dos Amortizadores do Cubo Traseiro
Dica: Usar os da Ténéré e XT600E do paralelo
Mago - 2005 - 12.000 km - 90,00
Mago - 2005 - 36.000 km - 90,00
Hoffmann – 2007
Alex Ramos - 2007 - 20000km - 130,00 Reais
Vazamentos na Suspensão Dianteira
Dica: Exigir troca dos retentores na garantia
Serra - 2006 - 5.800 km
Desgaste Prematuro do Pinhão
Dica: Usar pinhão paralelo, original tem preço absurdo.
Motor Apagando em Baixa Rotação
Dica: REGULAR A MARCHA LENTA PARA 1.400 RPM, esta é a rotação indicada no manual.
Mago - 2005
Betão-MG - 2007 - 5.700 km
Falta Lubrificação Rolamento Superior Direção
Dica: Dica?
Mago - 2005 - 15.000 km - R$ 170,00 - Trocado
Retrovisores
Dica: (Tem alguma dica?)
Freire - 2006 - (Falta Km, Custo) Trocado na garantia
Kezaum - 2006 - 8.000 km (Não dava mais aperto)
fhamaral - 2006 - 8.500 km (Não dava mais aperto)
Ventoinha não liga
Dica: Exigir troca na garantia
fhamaral - 2006 - 8.000 km - Travamento do motor
Alex Ramos – 2007 – 6.000 km - Trocada na garantia
Led luz alta piscando, oscilando
Dica: Qual é a dica?
Pirata - 2005 - Tentando descobrir
Buzina queimada
Romulo - DF - 2005 - 20.000 km
Alex Ramos - 2007 - 20000km - 53,00 Reais
Esticador da corrente
Dica: Verrrrr
Amauri carioca – 2006 – 12.000 km
Adesivos trincados
Dica: Verrrrr
Vazamento óleo bengalas
Dica: Trocada haste interna e retentores na garantia
hoffmann - 2007 -700 km
Corta corrente falhando
Dica: Lubrificar com desemgripante
Leosfat – 2005 – 15.000 km
Sensor de inclinação – Erro 30
Dica: Troca do sensor
Ruy-MT – 2007 – 902 km
Quebra do descanso lateral
Dica:
Ruy-MT – 2007 -
Jaborá, SC - Brasil
27 ago 2009 18:41 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Agora, o mais sério, e que tem dado extrema dor de cabeça aos proprietários, e a queima da ECU, o antigo CDI.
Muitos tem ficado na estrada por causa disso, ela queima do nada, não tem reposição, aqui custa quase R$ 2.000,00 e tem gente de cabelo em pé, pois não se sabe por que ela queima.
O cara está na estrada, rodando, de repente a moto desliga e já era, nem com a chave vermelha não se resolve.
Inclusive, acho até que você poderia conhecer o fórum brasileiro, para pegar dicas das nossas tão rodadas XTRs...
Olha aqui: http://www.forumxt600.com.br/forum/portal.php
Eu estou aqui: http://www.forumxt600.com.br/forum/prof ... ile&u=2088
Avisa... :okkk:
Jaborá, SC - Brasil
27 ago 2009 18:46 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
vfigueiredo Escreveu:
Já agora:
será a avozinha?
Está magnífico !!!
Coisa mais linda , ficava bem na minha sala :)
31 ago 2009 14:22 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Obrigado Robson!
Vou dar uma vista de olhos [wink]
XT 350cc
XT 750Z Ténéré
03 set 2009 22:14 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
