Data/Hora: 20 abr 2026 17:26
 Afinar Sag
Mensagem Afinar Sag
Nao encontrei um topico certo, anda por ai a informaçao mas toda espalhada...
Andava a pesquisar sobre o sag correcto e encontrei alguma informaçao:
Most motorcycle suspension is set up for a rider weighing 170lbs with a helmet and riding gear and carrying a maximum of 15lbs of luggage. If you exceed those numbers or are installing a new aftermarket shock, it’s a good idea to check the sag on your suspension.
Suspension sag can be adjusted by adding or removing spring preload on your shock. Motorcycle suspension is designed to be ridden with about 30% of the overall travel used when the rider and luggage are added to the bike. An appropriate sag setting will allow your motorcycle to have 70% of its suspension travel available to absorb upward movement of the wheel and 30% available to let the wheel drop down into dips in the road or uneven terrain to keep your tire in contact with the ground. Most adventure bikes are equipped with remote hydraulic preload adjusters that make it convenient to adjust the rear suspension sag. Remember, any time you add or remove weight from the bike you should measure and adjust your suspension sag to keep your bike handling properly.
For adventure motorcycles we are primarily interested in the ‘race sag’ which simply means the sag from the weight of the bike and rider.
When the ‘race sag’ is set correctly the bike will ride down the road level with the suspension positioned with the correct ratio of up and down travel available to keep the ride smooth and the tires on the ground. It also ensures that the correct geometry is achieved allowing proper steering and handling. Note: A bike that is sagging too far will have slower turning and a diminished feeling of control by the rider.
Most manufactures provide a sag specification for the rear suspension. This number can be presented as a measurement (ex. 60mm), as a percentage (ex. 30%), or as a ratio (ex. 135:65). If this specification is not available, you can simply take the total rear suspension travel of your motorcycle and use 30% of that number as your “race sag specification.” If your motorcycle has 10 inches of suspension travel at the rear wheel, and the manufacturer has not provided a sag specification, then it is safe use 3 inches (30% of 10 inches) as your race sag.
Example: BMW provides the ratio of 135:65 for the rear suspension of the BMW R1200GS. This means that the rear suspension has 200mm total travel and 65mm of that should be used as race sag. In this case the sag specification equals 32.5% of the total suspension travel.
How to measure your ‘Race Sag’
It's best to ask a friend or two to help you with this process. Having an extra set of hands will make it much easier to take measurements while the rider is on the bike.
Here's what you'll need:
1) Your motorcycle loaded with all the gear you are trying to set the suspension up for.
2) Rider fully dressed in riding gear.
3) Masking tape and a marker
4) Measuring device (tape measure or yard stick with fine increments)
5) Paper and pencil
The goal will be to fill out this simple equation:
Measurement A. (fully extended) – Measurement B. (rider and gear) = Race sag
Step One:
Place the motorcycle on the center-stand or a bike lift so that the rear wheel is off the ground. With the rear suspension fully extended, use your tape and marker to mark the center of the rear axle and a fixed position on the fender or seat of the motorcycle directly above the mark made on the rear axle. Measure the distance between these two marks and write it as “Measurement A. _______.”
Step Two:
Remove the motorcycle from the stand and have the rider sit on the bike with both feet on the pegs. Have a friend help balance the bike. The suspension should compress from the weight of the rider and the gear. If you are setting the bike up for a passenger, be sure to have the passenger wearing their gear sitting on the motorcycle for this step, too. Measure the new distance between the two marks and write it down as “Measurement B. _______.”
Step Three:
Now use these two numbers to find the race sag:
Measurement A (fully extended) – Measurement B (rider and gear on bike) = Race sag
informaçao retirada daqui:
http://www.touratech-usa.com/adventure/ ... ension-sag
Pelo que percebi, a mota tem que descer 30% quando está com o piloto em cima?
Partindo para o caso da minha que tem 240mm de curso no descanso central, se me sentar nela, tem de descer 72mm para o sag estar correto?
Muitas mais informaçao sobre suspensoes aqui:
http://www.ktm950.info/how/Suspension%2 ... _shop.html
(para abrir as varias informaçoes, clicar nas imagens)
Tem tambem alguma informaçao aqui:
http://www.ktmtwins.com/techtips.html
07 ago 2013 15:59 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mensagem Re: Afinar Sag
Já agora um complemento à (excelente) informação apresentada, onde dá para ver todos os procedimentos referidos para ajustar o "sag".
Cumps
08 ago 2013 09:58 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Careca na tua para afinares o sag de tras como deve ser tens de tirar anilhas quase de certeza!!!
Tu andas a nanar :cachaço:
08 ago 2013 10:37 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
E só se consegue o SAG correcto se a mola for a indicada para o peso do Mamifero que se senta lá em cima
08 ago 2013 10:57 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Carago, so vi agora estes posts...
Ja troquei as molas da frente de 4.9 para 5.9 e melhorou consideravelmente.
18 ago 2013 17:51 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Careca e a 5.9 é a mola correta para ti ???
JÁ CALCASTE UMA ROMANA??
E que tal porradinha nos braços ou nem por isso??
19 ago 2013 16:46 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Ainda nao a meti na pedra depois disso, está muito calor. :)
19 ago 2013 22:05 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
andas muito mimalhote :cachaço:
19 ago 2013 22:47 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Gravataça Escreveu:
O 5.9 é para levar a namorada a passear páh... não pescas nada! :lol:
23 ago 2013 19:10 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
