Data/Hora: 30 abr 2026 03:42
 Aprilia RXV 450 Tuareg Rally Replica 2011
Mensagem Aprilia RXV 450 Tuareg Rally Replica 2011
ake Model
Year
2011
Engine
Liquid cooled, four stroke, 77° V-twin cylinder,
Capacity
449
Bore x Stroke 76 X 49.5 mm
Compression Ratio 12.5:1
Induction
Integrated engine management system controlling ignition and fuel injection. Throttle body: 38 mm
Lubrication Dry sump with external oil tank. Separate gearbox lubrication
Ignition / Starting
Electronic / electric
Lubrication Dry sump with external oil tank. Separate gearbox lubrication.
Clutch Multiple discs in oil bath with mechanical
Max Power
Max Torque
Transmission / Drive
5 Speed / Chain Transmission ratio: 15/46 15/48
Frame Steel perimeter frame with alloy vertical members.Lightweight rear subframe
Front Suspension
50mm Marzocchi hydraulic fork, double adjustment upside down
Rear Suspension
Box section aluminum swingarm with cast body with a reduced thickness. Hydraulic shock absorber adjustable in rebound and compression.
Front Brakes
Single 310 mm floating disc in stainless steel with internal aluminum bell, floating caliper Nissin Braking
Rear Brakes
Single 240 mm floating caliper Nissin
Front Tyre
90/90 -21
Rear Tyre
140/80 -18
Exhaust system Euro 3 lateral exhaust.
Seat Height 1038 mm
Exhaust Dual stainless steel exhaust down Arrow
Dry-Weight
120 kg
Fuel Capacity
35 Liters divided into four tanks, two front and two rear
Steering damper PGR, Regina chain, fenders, hull, sump guard in carbon / kevlar
A bike ready to race, manufactured and assembled in “Noale Racing Department”, which always builds up the best machines for every discipline: A bike that holds the best components and cured to the least detail, as for cycling as well as the engine, assembled with the same team of engineers that works on the RSV of the Superbike World Championship . The Aprilia RXV 4.5 Rally Replica is sold exclusively by Team Giofil. (giofil@giofil.com)
http://www.giofil.com/
13 jan 2011 17:05 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mensagem Re: Aprilia RXV 450 Tuareg Rally Replica 2011
Preços : http://www.giofil.com/v/aprilia-tuareg-45/vendita/
13 jan 2011 17:06 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
não haja duvidas a mota é podre de bonita... :ave:
13 jan 2011 17:29 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mas 37.000€.... upa upa
Se ainda fosse a 35.000€ considerava...
13 jan 2011 18:00 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
30.000 e era minha :D :D :D :D
BMW GS 1200 triple black 2011
Vespa 150 Sprint 1969
Honda CN 250 1996
13 jan 2011 18:44 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Tem um som :unibrow:
13 jan 2011 19:27 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Já viste alguma?!
Ao nível do som, nada como os V2. Os V4 também são bons, agora os monos é barulho pouco refinado... :music:
13 jan 2011 23:44 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
:eek:
Muito bonita :D
:ave:
14 jan 2011 09:20 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Vou mandar vir 1 .
Alguém quer aproveitar e partilhar os portes ?
14 jan 2011 09:49 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Vou mandar vir 1 .
E que tal uma compra de grupo?
14 jan 2011 10:00 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Vou mandar vir 1 .
Eu pago os portes e a moto fica para os dois, Boa????????
14 jan 2011 10:17 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Vou mandar vir 1 .
14 jan 2011 10:28 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Ok , já mandei vir , Nuno e BC , eu já meto o meu NIB :thumbsup:
14 jan 2011 10:36 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Tem pouco azul... :baa:
14 jan 2011 14:57 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Pronto tá bem, eu ajudo-te a colocar vinil azul na mota ou a pinta-la... não insistas mais :lol:
14 jan 2011 15:01 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Por acaso também gosto imenso do barulho do V2, é fabbuloso! Faz lembrar o motor da Lc8 mas um pouco menos encorpado.
Já agora, a título informativo, que é que acham das condições desta aqui ?!
http://marinhagrande.olx.pt/moto-aprili ... -152562772
14 jan 2011 16:30 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Vitor,
4000 € está dentro dos preços das suas concorrentes desse mesmo ano, tem de facto é muito poucos quilometros.
No entanto CREIO que no inicio as RXV tiveram alguns problemas de fiabilidade, investiga.
Outra questão que para mim é fundamental, sobretudo em motos deste tipo, assistencia e respectivo preço.
No meu caso só devo comprar ktm e hondas uma vez que são as duas marcas que me garantem assistencia em Milfontes, se tivesse uma BMW ou uma Aprillia nem uma manete aqui arranjava.
No entanto a exclusividade tem o seu preço.
14 jan 2011 19:17 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
