Data/Hora: 30 abr 2026 07:10
 Benelli Tre 1130 K Amazonas
Mensagem Benelli Tre 1130 K Amazonas
Alguém conhece?
General information
Model: Benelli Tre 1130 K Amazonas
Year: 2007
Category: Enduro / offroad
Rating: 66.8 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 1130.00 ccm (68.95 cubic inches)
Engine type: In-line three, four-stroke
Power: 123.37 HP (90.1 kW)) @ 9000 RPM
Torque: 115.00 Nm (11.7 kgf-m or 84.8 ft.lbs) @ 6250 RPM
Bore x stroke: 88.0 x 62.0 mm (3.5 x 2.4 inches)
Fuel system: Injection. Electronic injection with 1 injector per cylinder
Fuel control: DOHC
Ignition: Single coil inductive discharge electronic ignition
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: 6-speed
Transmission type,
final drive: Chain
Clutch: Wet clutch
Chassis, suspension, brakes and wheels
Frame type: Mixed solution. Front: ASD steel tube trellis,
Rear suspension: ASD steel tube trellis swingarm with
Front tyre dimensions: 120/70-17
Rear tyre dimensions: 120/70-17
Front brakes: Double disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc. Bremo
Physical measures and capacities
Dry weight: 205.0 kg (451.9 pounds)
Power/weight ratio: 0.6018 HP/kg
Wheelbase: 1,514 mm (59.6 inches)
Other specifications
Starter: Electric
Parece ser um misto de TDM900 com Varadero.
Dei por mim a ler num site que fizeram uma expedição ao Amazonas com motos destas:
http://www.benelli.co.uk/amazonas_video.html
16 jan 2011 17:04 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mensagem Re: Benelli Tre 1130 K Amazonas
ja conhecia. Tenho uma migo meu que tinha uma Trek! Muito bonita, mas tava lhe sp a dar problemas eléctricos !
17 jan 2011 12:29 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
17 jan 2011 16:57 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
E ainda dizem mal da XT12...
18 jan 2011 12:56 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Por acaso esta Benelli tá bem fixolas , comparando com o que por aí anda do mesmo segmento .
18 jan 2011 14:28 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
So pode ser brincadeira....a mota é totalmente de estrada!!!! Meteram uns Karoo e siga...
18 jan 2011 15:16 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
É o equivalente a uma V-Strom 1000 ......... por aí ........
Mas o motor é outra fruta !
18 jan 2011 15:26 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Por acaso também acho! É que nem se deram ao trabalho de fazê-la "parecer" uma trail... :D
18 jan 2011 15:36 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
