Data/Hora: 24 abr 2026 00:36
 Moto Guzzi Stelvio 1200 NTX NO-LIMITS VERSION
Mensagem Moto Guzzi Stelvio 1200 NTX NO-LIMITS VERSION
DESIGN
• New headlight fairing.
• New 32 litre fuel tank.
• New windshield.
• New saddle lining.
• New Moto Guzzi customised side panniers.
• Brand new shaped saddle.
ENGINE
• 1200 90° V-shaped Twin-cylinder "Four Valve"
• Single overhead camshaft timing system with decreased valve control noise level.
• New profile camshafts.
• Oil radiator fitted on the lug.
• Single plate clutch.
• New exhaust system.
• Transmission with compact reactive cardan shaft drive.
• 6-gear gearbox.
• Euro 3.
CHASSIS
• High tensile steel upper dual beam frame.
Front fork with 50 mm legs, adjustable spring preload and hydraulics fitted with a new set of progressive action springs.
• Shock absorber with adjustable preload and rebound fitted with a new more preloaded spring
• Rear suspension with progressive articulation single arm.
• 4 horizontally opposed piston front brake system with new 320 mm discs.
• Rear 282-mm disc brake, floating calliper with two parallel pistons.
• Rear tyre ZR 150/70/17.
• Front tyre ZR 110/80/19.
STANDARD OUTFIT:
• New cutting-edge Continental ABS.
• New instrument panel with increased scale fuel level indicator.
• Heated hand-grip fixture.
• Satellite navigator fixture.
08 jun 2011 09:04 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mensagem Re: Moto Guzzi Stelvio 1200 NTX NO-LIMITS VERSION
Há muitas moto guzzi que verdadeiramente me atraem, destaco as inimitáveis Califórnia ou outras igualmente interessantes, sempre dentro da filosofia "naked" ou "cutom", as verdadeiras e únicas guzzi.
Ao contrários da triumph 800 que entrega ao segmento a novidade de um motor 3 cilindros, que segundo consta é uma delicia, esta Stelvio parece-me uma rude imitação das GS (A) que não adicionam nada de novo, antes pelo contrário.
08 jun 2011 09:31 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Eu vi esta moto ao vivo e fiquei impressionado com a diferença de tamanhos entre uma GSA e esta .
A GSA ao pé desta é enorme e a Stelvio parece quase uma miniatura .
08 jun 2011 09:34 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Não há muito o Elbling era o distribuidor para Lisboa das Guzzi, por isso não só as vi como até dei uma muito pequena volta na Stelvio, é certo que mal deu para a testar, mas também é certo mas deu para perceber 3 coisas:
1 - O conforto está acima de qualquer suspeita, uma delicia, eventualmente só comparável com a GS
2 - O motor é estranho, é guzzi, requer hábito..
3 - TT com isso, não!
08 jun 2011 09:45 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Paulo, eu quando começo a pensar em outras trails, revejo este video que gosto muito, não tem saltos, nada de malabarismos, apenas um simples teste e um tipo que transmite bem o que é uma uma verdadeira trail.
Provavelmente já o conheces, mas revê, a mim desgraçou-me uns euros e fez-me voltar ao mesmo.
http://www.youtube.com/watch?v=klSNp2uuh8M
08 jun 2011 10:16 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Temos vídeos melhores aqui no Trail Aventura :lol:
08 jun 2011 11:08 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
sem duvida pedro ainda o fim de semana passado andei na tua Ex ktm e ninguem me tira da cabeça que a maquina é practicamente pau para toda a obra ainda por cima com o meu tamanho não me sinto bem em cima de mais nada [hum]
08 jun 2011 11:15 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
PauloBig Escreveu:
Estás a falar de que mesmo??? :lol: :lol: :lol: Tu vê lá pah.....
Acho a Stelvio assim uma coisa tipo um Cancro!
08 jun 2011 13:08 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Pedro,
Partilho das tuas opiniões. Tenho um fetiche por Moto Guzzi, talvez pela minha primeira moto ter sido uma V35III. Aliás, ainda não perdi a esperança de a comprar de novo ao actual dono.
Concordo plenamente. Embora a California não seja bem ao meu estilo é um clássico; as guzzi mais recentes são lindíssimas, desde a Centauro - que havia aí há uns anos - às actuais V7 Classic. Ainda esta semana vi uma na IC19 e vim um bocado ao lado dela a babar.
Tive oportunidade de andar numa Stelvio no Travel Event e concordo contigo. Se eu já achava o boxer meio estranho então estas...coisas esquisitas. Em baixas parece que andam martelos dentro do motor.
Achei no entanto a mota muito "manobrável".
joão pedro barreiros
bmw r850gs, 1998
bmw r80gs, 1990
08 jun 2011 13:15 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Tirei estas fotos no salão de Milão em 2009 esta ao jeito de supermotard [hum]
Um must have in the garage [hum]
Editado pela última vez por Paulo Li em 12 jun 2011 19:34, num total de 1 vez.
12 jun 2011 19:16 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Esta versão desportiva [:p]
Pormenor do pneu
Esta parte foi a que causou sensação
Esta é um must have in garage
12 jun 2011 19:28 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Bem, parecem quadrados autênticos. :shi:
12 jun 2011 19:45 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
