Data/Hora: 03 mai 2026 20:52
 Scala Rider G4 Powerset (Vendido)
Mensagem Scala Rider G4 Powerset (Vendido)
Estou a vender o meu conjunto de intercomunicadores Scala rider G4 Powerset, estão em optimo estado! Motivo upgrade para o G9.
Valor novos 440€, vendo por 300€ negociaveis.
Tenho tudo tal como vieram, caixa, carregador, cabo USB e bases de fixaçao para os diversos capacetes.
Para mais detalhes:
http://www.cardosystems.com/scala-rider/scala-rider-g4-powerset
Characteristics:
General
Talk time: up to 13 hours
Standby time: 7 days
Charging time: 3 hours
Certificates: FCC, IC,CE, IP67, Bluetooth®
Bluetooth® version 2.1 class 1
Chip manufacturer: Cambridge Silicone Radio (CSR)
Battery type: Rechargeable Li-Polymer
Digital Signal Processing (DSP) for advanced audio
Compatible with entire scala rider product line**
Intercom (up to 1 mile/1.6 km in Full Duplex)*
4-Way (2 drivers and 2 passengers)
3-Way (3 separate bikers)
2-Way (rider-to-rider or rider-to-passenger)
Click-to-Link: for spontaneous intercom connections with any G4 user
Mobile Phone Conference Mode (rider, passenger, outside caller)
GPS (requires headset profile)
Compatible with most major Bluetooth GPS devices
GPS voice instructions override music, FM Radio and Intercom calls
Supported Mobile Phone Profiles and Functions
Handsfree profile
A2DP/AVRCP profile for wireless streaming stereo from your MP3 player, iPhone™ or other smartphone
Voice Dial
Redial
Call Reject
Conference mode between outside caller, Driver and Passenger
Built-in FM Radio with RDS
87.5 MHz to 108 MHz FM receiver
RDS functionality (adjusts to best frequencies according to zones) RDS functionality for automatic selection of the strongest Radio signal while on the go (this is the text from the data sheet)
6-station memory with Search and Store functions
Automatic radio muting for incoming calls
Radio on time: 8-10 hours
Software Update
Software update-ready directly from PC (requires PC running Windows® XP™, Vista™ or Windows 7)
MP3 / Music
Connect wirelessly to A2DP / AVRCP enabled MP3 players for Bluetooth stereo music (Cable option also provided)
Mechanical / Functional Features
Fits virtually all full-face and 3⁄4 helmets (also available in corded microphone version for full-face helmets)
Quick-release mechanism to detach scala rider G4 from audio kit
Glue-on option included (instead of clamp attachment)
Two slim speakers to fit even the tightest helmets
Multiple control buttons
Mobile phone
Channel to Rider A
Channel to Rider B
Volume Up
Volume Down
FM Radio
MP3 Player
Audio Features
The G4 is equipped with AGC technology (Automatic Gain Control), allowing the automatic increase or reduction of volume according to ambient noise and driving speed. You can also control the volume level manually.
AGC sensitivity levels can be customized to suit your personal preferences:
Low AGC Sensitivity will require less ambient noise in order for the AGC to be activated, causing AGC to increase the volume on the headset at lesser speeds than usual
High AGC Sensitivity will require more ambient noise in order for the AGC to be activated, causing AGC to increase the volume on the headset at greater speeds than usual.
VOX technology: The G4 offers VOX technology for safe and hands-free operation of some key functions (Voice Dial, Answer Call, Reject Call). The VOX feature can be turned ON or OFF according to your preference. Voice-control for receiving / rejecting incoming mobile or intercom calls. Customizable sensitivity levels for enhanced experience.
VOX sensitivity levels can be customized to suit your personal preferences:
Low VOX Sensitivity will require more noise in order for the VOX to be activated, making it more difficult to trigger.
High VOX Sensitivity will require less noise in order for the VOX to be activated, making it easier to trigger.
Noise cancellation microphone
Multi-Lingual Spoken Status Announcements
Design
Flip-Up Antenna for extended range of up to 1 mile/1.6 km
Waterproof and dustproof – certified to meet IP67 standards
Rugged and streamlined design
Charger
110/240V 50/60Hz Universal Travel Charger
Charger unit uses USB cable that also serves as software download cable.
* Results may vary according to terrain.
**Reduced operational range when connected to earlier scala rider models
Editado pela última vez por B@ptist@ em 30 out 2012 20:25, num total de 1 vez.
29 out 2012 17:24 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Mensagem Re: Scala Rider G4 Powerset
Tem quanto tempo e é feito de que material?
29 out 2012 21:00 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
Faz dois anos no mes que vem sendo que ainda tem cerca 30 dias de garantia de fabrica.
Quanto ao material é uma boa pergunta mas so vejo plastico e borracha.
Isto é tudo que vejo no site da scala, se é PVC ou poli qq coisa sinceramente nao sei, mas que é resistente É!
The scala rider G4 redefines the notion of high-end communication for motorcycle helmets. Encased in a rugged yet streamlined body, the scala rider G4 offers Bike-to-Bike Intercom at a remarkable range of up to 1 MILE/1.6 KILOMETERS!*
Posso enviar-te fotos detalhadas para um email que forneças.
O valor é negociável!
29 out 2012 22:13 { SHARE_ON_FACEBOOK } { SHARE_ON_TWITTER }
